Hei,
trenger litt hjelp med å finne ut va feilkodene betyr og va som trengs av deler etc ,for å få fikset. Kanskje også tyde verdiene for å se at det stemmer med hvordan det skal være.
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 4222:Glow plug cylinder 2, control ***
 Fault-Set 1 - ( 184568 km)
     Air mass per cylinder: 321.38 mg/Hub
     battery voltage: 14.17 V
     Boost pressure actual value: 1024.00 mbar
     Coolant temperature: 46.11 deg C
     Engine speed: 661.98 1/min
     Injection quantity: 8.27 mg/Hub
     Pedal value generator: 0.00 %
     Rail Pressure Is: 362.34 bar
     State of the glow indicator: 152.00 -
     vehicle speed: 0.00 km/h
 Fault-Set 2 - ( 184928 km)
     Air mass per cylinder: 340.28 mg/Hub
     Boost pressure actual value: 964.92 mbar
     Coolant temperature: 59.16 deg C
     Injection quantity: 9.85 mg/Hub
     Rail Pressure Is: 338.71 bar
     State of the glow indicator: 148.00 -
*** 3EED:Power Management quiescent current (Layer PMRUHVERL) ***
 Fault-Set 1 - ( 184616 km)
     Battery power of IBS measured: 7.99 A
     battery temperature: -0.00 deg C
     Battery voltage of IBS measured: 12.27 V
     Coolant temperature: 20.01 deg C
     Engine speed: 0.00 1/min
     Injection quantity: 0.00 mg/Hub
     Quiescent current time between 200 mA and 1000 mA: 0.00 min
     Quiescent current time between 80 mA and 200 mA: 627.20 min
     Quiescent current time than 1000 mA: 0.00 min
 Fault-Set 2 - ( 184688 km)
     Battery power of IBS measured: 141.42 A
     battery temperature: 7.85 deg C
     Battery voltage of IBS measured: 11.31 V
     Coolant temperature: 7.96 deg C
     Engine speed: 137.91 1/min
     Quiescent current time between 80 mA and 200 mA: 1896.53 min
