1973BMW 2000 Touring
Lefton Lefton
Hello Bimmer.no people! i apologise in advance as this thread will mostly be in English is my Norske is Ikke Bra!!!
Bought this car off a fine gentleman in Haugasund, perhaps he's on here? so i bought the car welded and painted but il add it to the thread as i basically have taken over the project half way through!
See below the specs thus far!
Engine & Drivetrain:
2.0L single carb M10 Engine
5 Speed Getrag 320i gear box
Standard Open dif.
Standard exhaust with aftermarket backbox -will be changed looks a tad chavvy
Suspension & Steering
Bilstein Stage 2 racing shocks front and rear.
Ireland Engineering Stage 2 racing springs front and rear
New strut top Strut top mounts
Ireland Engineering Fixed Camber Plates.
All suspension rubbers replaced with poly urethane bushes front and rear.
New Ball joints.
Poly-urethane steering coupler
New Tie rods & Steering Linkage
Ireland Engineering 22mm hollow front swaybar
Ireland Engineering 22mm Solid Rear Sway bar
Brakes:
Upgraded Willwood 4 piston calipers front
Upgraded Willwood conversion rear.
Slotted and drilled discs
EBC Street pads
Interior
Fully refurbished standard interior.
Looking for a nice steering wheel currently
Wheels & Exterior
In process of looking!
Resprayed in Verona red (original colour)
11007747_953642687992678_593346303603361
10421993_953642691326011_816473241650319
15529_953642684659345_835815615687653694
11130145_953642721326008_106145875566851
11150238_953642724659341_443952929787782
11148760_953642747992672_248564939716436
1908203_953642751326005_4777028197461072
Post Re-Spray
11112558_953642824659331_568621740433895
11146211_953642827992664_678357015535188
11040172_953641114659502_661371008798887
11148440_953641217992825_89128813175728510491093_953641787992768_309786100695008
Interior
11136646_953641207992826_494943090566739
11138131_953641194659494_863408806527077
17629_953641234659490_278595027449410842
When i got the car into the lock up and gave it a good inspection it has a leaking sump, gearbox, dif and everything was looking a bit tired, no fault of the previous owner but i knew it was a fixer up car so i was quite happy as this meant i could buy some nice shiny new parts!!
Full stage 2 upgrade racing kit and all new poly bush all over!
10410785_973832635973683_897929592179422
11080994_946608332029447_443316086552105
11127817_953635657993381_203988106274175
10930195_953635587993388_124331008203669
11088535_953635547993392_784649183099025
11112849_953635521326728_372172310281158
Subframe stripped down
11695032_1001684823188464_62800447459249
Found cracked engine mounts
11696023_1001684839855129_59610299373362
11698738_1001684866521793_92052552045471
11667277_1001684919855121_88180841319401
11700862_1001684939855119_32231731780853
11667249_1001685089855104_37903712949047
12662508_1108114495878829_91181974704699
12642699_1108114499212162_71219920093547
10685436_1108114582545487_43559225257236
12651378_1108114585878820_60406048487705
12647378_1108114645878814_88008767984221
12670259_1108114649212147_38729419332304
Figured out how to fit these camber mounts eventually! so simple but man i was confused haha!!!
12644916_1110899932266952_3497570113690412645077_1110899935600285_89347265155895
12670315_1110900025600276_71618388684108
12650931_1110900022266943_81429912666272
bit of a milestone suspension fitted again! if i hadn't ruined the suspension arms the other day.
12654534_1110900028933609_88256041929922
12651279_1110900112266934_11093133036474
12661985_1110900115600267_14272272712654
And  a cheeky front pic since i still think its such a bonnie car from the front!
(some cheeky poly bushes poking out below!)
12670307_1110900165600262_68776245216339
