Orjan Skrevet Desember 9, 2021 Skrevet Desember 9, 2021 Her dere fått med dere denne? Tøft Singer-aktig konsept på den evigunge BMW E30 M3. Firmaets hjemmeside: BMW E30 M3 | Enhanced & Evolved by Redux (reduxleichtbau.com) Sitat Engine Re-engineered S14B23 (2.3l) rebuilt to Redux's S14B25 (2.5l) specifications, including: BMW Motorsport crankshaft Bespoke engine wiring loom with Autosport connectors 95mm pistons MoTeC M130 Engine Control Unit (ECU) Redux billet aluminium valve cover Exhaust Custom manifold and hand-crafted stainless steel exhaust system* (with catalytic converters) Transmission BMW Motorsport 3.91 crown and pinion Limited Slip Differential (LSD) TTV lightweight flywheel and clutch 5-speed dogleg** manual gearbox with close-ratio gears Sitat AP Racing Brake System Front: 362 x 32mm rotors with 6-piston calipers* Rear: 315mm x 28mm rotors with 4-piston calipers* Bilstein or EXE-TC Dampers Adjustable top mounts Coil over dampers* Custom billet hub carriers Front and Rear Assemblies Adjustable front control arms Adjustable front and rear anti-roll bars Bump steer and roll centre spacers Upgraded bushings and revised geometry Cinel Wheels and Michelin PS Tyres Cinel 18-inch forged, lightweight, aluminium monoblock wheels (5×120 PCD or centre lock*) Michelin Pilot Sport 4 (225/40 ZR18, 255/35 ZR18) Michelin Pilot Sport Cup 2* (225/40 ZR18, 265/35 ZR18) Magnus., NA, Ingvaldsen og 2 andre reagerte på dette 3 2
Øyvind L. Skrevet Desember 9, 2021 Skrevet Desember 9, 2021 Tror de har glemt å senke den. Stolene foran ser jo ut som billige kopistoler fra eBay... Huff.
Olaandref Skrevet Desember 9, 2021 Skrevet Desember 9, 2021 Syns takspottene som erstattet frontlyktene var verst 🙂 EasyL reagerte på dette 1
Øyvind L. Skrevet Desember 9, 2021 Skrevet Desember 9, 2021 3 minutter siden, Olaandref skrev: Syns takspottene som erstattet frontlyktene var verst 🙂 Og luftintakene i fangeren foran. Så ille ut. Olaandref reagerte på dette 1
