10055 -
Dager vunnet
111
Alt skrevet av StigJ
Det kalles en diskant på norsk Høyttaleren som lager de høyeste tonene.
Bra det kan brukes til noe vettugt
- 3 svar
- defekt vindushever
- vindusmekanisme
(og 5 andre)
Merket med:
Her kommer det en DIY jeg laget for å bytte vindusheismekanismen. Dette er da på Z4en min, men skal være veldig likt på E46 også etter hva jeg husker (har byttet på en slik også). Så kan sikker hjelpe til der også. Here goes So here is an, I hope, ok writeup of the swap for you to use if your time is up for this job. Please look through the whole DIY before doing it yourself I had also bought a new water splash cover. This needs to be changed also. You will not be able to remove that in one piece. Also had some Dynamat sound deadening sheets for deleting the tin foil sound when closing the doors. Hate that. Sounds cheap.... Had some Tec7 to glue and seal the splash cover in place. Disconnect you battery. You will need to remove the door airbag. Remove the 10mm hex nut on the battery's ground terminal. Removing of the door panel. Locate all the Torx T25 screws that holds it in place. Pop out the plug with the Airbag logo Unscrew the T25 Remove the trim on the door handle. Begin at the top. I did not. So I broke a little plastic lip on the bottom of the trim. So pry out from the top and slide it down a little. Unscrew the two T25's Then I found the smallest flat screwdriver I had. Gently pry out the plug that sits over the screw on the door opener. Unscrew the last T25 Remove the power button for the window. Just pry up. Then unplug the connector on the underside. Wedge something flat that is made of a material that will not scratch between the door and the panel. Pop out and work you way around. At the top you need to apply some more force to get it off. It should be pulled out (towards you). Not upwards like on many other cars. Begin in the one end and work our way along the window. (I usually begin on the end with the door lock pin.) You can see the metal clips 3 pictures down. Pull off the wire to the door opener. Just grab it like in the pic and pull up/out. Door panel is off. Now you can see the metal clips along under the window. Now you need to remove the airbag. 3 pcs. 10mm hex bolts Unplug the connector for the airbag. So off to the crappy part. Removing the splash cover. Start peeling off the cover. Remember to also remove all the black seal. Its very important that you get the new cover fully in place without gaps. If you don't you will have a little pool of water inside your car after a while. All removed. Ok, now you need to align the window mechanism and the bolt that holds the window. So connect the Airbag, and connect you battery. You need power for the window. Align so you can see the bolt in this hole: You see it in the picture of the whole door just above. Well, If you think a little ahead, something I didn't do You can disconnect the battery after removing the door panel. And before you remove the airbag you can just punch a hole in the splash cover to align the bolt On to the removing of the window. Unscrew the Torx T40 bolt that holds the outer/right side of the window. Remove the locking clip on the inner/left side of the window. Use a flat headed screwdriver to pull it to the left. Here is a better picture of the holder of the window. Forgot to take a picture of this. But just take a flat headed screwdriver and pry the ball out of the socket to remove the window. Now the window is loose and can fall down. The best thing now is to take off the plate that the T40 bolt you just removed is going in to. I did not so I broke a little piece of it. It still works fine but it will be a little fiddle to get it in place again. There is a little plastic lip the you need to unlock to get the white plate off the window. You can see that just below. The you can pull up the window and remove it from the door. Just wiggle it a little to get the other fastening bracket through. Place the window on something soft to not scratch it. Here you can see the little lip that I broke. It hold the two sides of the plate together. Clean you window Now start removing the lifter mechanism. Unplug the connector from the motor. Still 10mm hex nuts First: Second: Third: Fourth: Remove the plastic plugs from underside of the door: And fifth: There is a little platic holder on the inside that holds one of the wires. Remove that. Now you can wiggle the whole mechanism out from the door. Crappy wire Remove the motor from the old mechanism and mount in on the new. 3 brass Torx T30 screws And you know what to do with the old one. Before installing the new lifter I wanted to put in some sound deadening. I used one sheet of Dynamat Superlite. Not that heavy Now you can install the new lifter. Just work backwards like when you removed the old one. Jus do not tigthen the hex nuts yet. You need to align the window a little later. Slide down the glass and align it to the rail that goes down from the mirror area. Use a good amount of time to get the window properly installed and aligned to the rails and brackets. Pop in the front bracket and secure it with the clip. Place the white bracket for the T40 bolt on the window. Then align it to the lifter. Here is a plate that you can adjust the window with. Here you just need to try a little. I hooked the airbag back on and the battery so I could adjust the window. Remember also the hex nut on the underside of the door. This is also working as alignment to the glass. The further out you fasten the nut, the more pressure the top of the glass is on the window sealing at the top. Then I put a nice thick strip of Tec7 around the exactly at the same place as the old gooey Remember that this needs to be all sealed so that the water do not run into your interior. Then start working backwords again starting with installing the airbag. Then the door panel, and finally the connecting the battery. Hope this will help someone. Thanks for reading
- 3 svar
- vindusmekanisme
(og 5 andre)
Merket med:
Bilder fra BMWCCN fellestreff i Haugesund (Årabrot)
emne svarte i StigJ sin BMWPower i Bilder og filmer / Show-off
Ja skikkelig trivelig treff i år også Madammen storkoste seg i passasjersetet på banen for aller første gang Hvem var det som kjørte den 1Men? -
Tror nok du må doble prisen på diffen. Da ferdig montert. Jeg fikler ikke med slikt selv tror jeg.... Jeg har H&R fjærer på originale M-Tech dempere. Det blir nok byttet til frodel for noe grommere med tiden. Regner med demperne takker for seg om ikke så lenge. De har jo stått på i 51k km nå så. Og i 25k av de med H&Rene. Blir sikkert H&R neste gang og. Cup kit kanskje? Synes det ble mye mindre krenging nå med stabstagene. Så jeg mener at det er verdt det ja Super, sport, stilig, stylish etc. Altså har ikke peiling
Prøver å ikke la det ta helt av med moddingen heller. Liker små og diskre detaljer. Har noen til som kommer fremover som er små men forhåpentligvis stilige. Koster jo skjorta med presse og diff. Men er sugen på det. Bremsene kunne jeg tenkt meg å gjøre så originalt som mulig. Komplett M Coupe/roadster understell kanskje? Bare sleng de ut her. Alltid kjekt med bilder
Kjekt du liker den Og etter over 4 år i mitt eie så liker jeg og den bare mer og mer Så derfor skal den forbli i mitt eie i mange år videre. Hysj på seg Har prisforespørsel ute allerede så.... Men om det skulle bli noe av så må det oppgraderes i andre bauger og kanter også. Quaife og bremser. Blir penger av slikt. Og så hadde det vært utrolig kjekt å fått det godkjent i samme slengen også. Hysj på deg og
Flesteparten av de awt nevner blir eller har blitt norskregget jo
GS Bildeler? De forhandler jo ACS.
Hva med å prøve de to forskjellige modellene selv? Tror nok du raskt finner ut hvilken du vil trives med. Gamlingen har en E91 LCI 318iA, og den er forsåvidt grei nok. Men hadde nok ikke valgt det selv. Diesel faller for meg gjennom uansett biltype siden jeg hater det Så da hadde jeg heller gått for en E91 320i manuell
Jeg har også truffet på denne. Og da mener jeg det var daglig leder hos Porsche Center som kjørte den. Bavaria Stavanger har vel hatt en inne allerede mener jeg å huske.
Såpass mye forskjell på coupe og touring ja? Jeg har 9.5 ET27 og 275. An anelse subb høyre bak av og til.
Kjør på med M Aero heller da.
https://www.google.no/search?q=e46+quad+exhaust&rlz=1C1GGLS_noNO366NO367&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=CxHrU6LTNoTXyQPHhoKoAw&ved=0CB0QsAQ&biw=1440&bih=815#q=e46+quad+exhaust+conversion&tbm=isch
