667 -
Alt skrevet av Maxmek
Feilmelding på hengerfeste - uten henger..! F11
emne svarte i Maxmek sin Overmo i Koding og diagnose
Hei, du har ikke en overgangskontakt stående I?? Da kan du få feilmelding. -
Full backup of Car's configuration files: It's a good practice to take a full back up of Car's original settings before any changes are made to the car. These files could be used as reference in case it is desired to go back to original settings of any or all features. Read and Save FA: Connect E-Sys to your car. Select "Expert Mode" on the left pane and click on "Coding" button therein. It will display 4 sections/Boxes on the right side. In Vehicle Order Box (upper left), click on "Read" button, it would display FA of your car under FA List. Select FA and click on “Save” button. Save as FA_original. Test button above will show the path of the saved FA file. Read and Save SVT: Look at SVT Actual Box (right pane, midway down) and click on "Read SVT" button. SVT box on left will display SVT of different modules of your car. Click on the Save button on SVT Actual box and name the saved file as SVT_original. Text button above will display the path of the saved file. Read and Save CAFD (ncd) files: Inside SVT box (left side), you see SVT, containing ECUs and each ECU contains files in expanded view. Notice that some of the CFD files will have green check marks. These green marked CAFD files are of our interest. Right click on first green marked CAFD and then press and hold control key on your laptop and click on all other similar marked CAFD files. This way all such CAFD files will be selected for further operation. Now move to right in “Coding” box and click on "Read Coding data". After codes are read, green icon will change into a folder icon and the files inside will contain the data read from your car. Check the folder "C:\Data\CAF”, this will contain all the read CAFD files. Copy and Save all the files in a safe place. These are your original CAFD files. Alternatively, you can use utility "Copy_CAF_v3.bat", copy it anywhere on your laptop and double click on it to automatically save the files under a Folder "C:\My_CAF_Files" with date and time stamp.
Hei, bare en liten oppfordring. Har lest flere plasser at man absolutt anbefaler å ta backup av orginalfilene FØR man begynner å kode noe. Hvis noe går galt har man mulighet for å legge tilbake orginalfilene.
Hei, noen som kunne ha laget en punkt for punkt liste hvordan man går frem (DIY) for å få remote app til å funke. På min bil virker internet med deling via mobil. Er ikke særlig skarp I tysk, så hva skriver dere I e-posten, og hvor sender dere den. Dette egenerklæringsskjemaet for eierforhold, hvor finner man det? Og hvilke detaljer må opplyses om? På forhånd takk
Hei, mener å huske at det er forskjell på turbo, dyser og girkasse på disse.
Hei min 530 xd har snittforbruk på 0,73 gjennomsnittshatighet 54 km/t På småkjøring nå I kulda 0,98 (ikke mye tomgangskjøring) Normal langkjøring 0,67 Langkjøring med "egg" på pedalen 0,58 Har også registrert at når active cruisecontrol er aktivert går forbruket på langkjøring opp ca 0,4 når det er litt trafikk. Kjører på Michelin Xice Xi3 bredde 225 piggfritt. Har også erfart at dårlig luftfilter kan gi ganske mye høyere forbruk.
Frank@ Sjekk linken til Bowers I tredje inlegg I denne tråden. Registrer deg og spør Sheridan om link til siste software og PsdzData, og du får raskt svar.
///frank Skrevet 04.01.2015 - 20:32 Hei. Har nå fått lastet ned BMW E-Sys 3.25.3 + PSdZData v2.51.3 men kommer ikke inn der du velger bilmodell på E-sys men bilen må være kontakt siden den får opp VIN nummeret. Har prøvd å installer på nytt og følger instruks som følgte med men kommer til det likens med at kommer ikke opp valg av bilmodell. Noen her som kan trø til Hadde same problem. Fikk opp vinnummer men ikke noe mer. Psdz-data må være av same versjon som bilens software eller nyere. v51.3 er for gammel fil til en 2014 modell, du må ha minimum v53.4 avhengig av når bilen er bygget eller oppgradert.
Hei, les førstesiden her http://bimmers.no/topic/683719-bmw-dieselmotorer/ og denne tråden. http://bimmers.no/topic/717240-chiptuning-520d-f11/?hl=%2Bbox+%2Btuning#entry2150828 Boks tuning ville jeg aldri vurdert til en F10, kanskje Hartge og AcShnitcer, men de koster mer enn å omprogrammer eller et orginalt BMW performance powerkit. Mange som har hatt problemer med tuningboks, vanlig er svart røyk ved pådrag.
Hadde same problem på min E60 2009. byttet begge thermostater uten at det hjalp noe videre. Har du webasto? sjekk isåfall den elektriske sirkulasjonspumpa. Denne laget problemer for meg. Edit: ble plutslig I tvil om det var en mangnetventil til sirkulasjonen av vannet I forbindelse med webasto som var problemet. Hadde da problemer med å få motor over 75'.
Hei, tydligvis ting på gang nå Da får vi vente å se hvordan dette gjøres. Hadde jo vært knall om man kunne bruke Ricas I-Softloader via OBD. BMW F-Series Tuning Upgrades!26-11-2014 In the first week of 2015 RICA Engineering will launch tuning upgrades for all the new BMW F-series. Both Diesel and Petrol engines. Some of you have been waiting a long time for this, but now we can finally say YES! All turbo-diesel and turbo-petrol engines can profit from a genuine RICA ECU upgrade! Wether you drive a BMW 114i or M5, the RICA power upgrade will bring a big smile on your face! No tuning-boxes but a real ECU upgrade! Stay Tuned! The RICA Engineering Development Team http://rica.nl/nieuws.php?news=75
Guide: Remote app på importbil
emne svarte i Maxmek sin Stratos i Bilstereo, multimedia og navigasjon
Hei, jeg får denne meldingen når jeg legger in vin nummer. Noen som vet hva som må gjøres?? Das Fahrzeug kann Ihrem Account nicht hinzugefügt werden.Bitte wenden Sie sich an die BMW ConnectedDrive Kundenbetreuung. Sie erreichen uns telefonisch unter +49 89 1250 160 10 (Mo. bis So. von 8:00 bis 20:00 Uhr inkl. Feiertage) oder per E-Mail an bmw-connecteddrive@bmw.de. Schließen -
Hei, nei Bowers BMW's power kit kan fås til automat. Jeg monterte sjøl dette på min nå I sommer. På min bil (530xd) var dette inkludert: større bremseskiver og kraftigere kaliptere(4-stempler) med nye klosser forand. Intercooleren blir byttet til større. Effektøkning: 28Hk(258-286) og 40Nm(560-600). Nå skal det sies at man merker ikke allverdens på en 530d, men snakket med en som hadde gjort det på en 520d 163Hk, og han var kjempefornøyd. Så hvis man nærmer seg skivebytte er det ikke dumt å investere I et M-Performance power kit.
Hei, har nå fått programmet til å virke. Men har fremdeles problemer. Det jeg har gjort er å laste ned E-Sys 3.34.3, og brukt Psdz-data ok Token(est) fila fra programmet som fulgte med kabelen( http://www.ebay.com/itm/151362340848 ), dette er V50.3. E-Sys programmet som fulgte med kabelen 3.23 fikk jeg ikke til å fungere. Alt går greit helt til jeg skal lese CAS(40) CAFD-fila. den vil ikke leses, den neste "grønne" CID CAFD leses ok, og det kommer opp mappe med +tegn. Har lest av I-step, og har versjon F010-14-03-503. Slik jeg har forstått det bestemmer vesjon av I-step hvilken versjon man minimum må ha av Psdz-data. I skjermbilde2 står det F010-13-07.505 kan noe av dette medføre at jeg ikke får lest av CAFD-fila?? Ellers har jeg testet med WIN-XP og WIN7, og begge ser ut til å funke fint med E-Sys. Men noe er altså galt hos meg, noen som har ideer om hva??
Hei, det er mange som kan levere tuning til Fxx, men det har vært forskjellige typer tuningbokser som overnevnte og bl.a AC-Snitzer, Autopower etc. Disse boksen er av forskjellig kvalitet, og styrer etter få eller flere parameter, men ingen av dem kan måle seg med en omprogrammering da alle nødvendige og ønskelige parametere blir hensyntatt.. Det har også versert en del rykter om OBD tuning, men har til gode å ha lest om noen som virkelig har gjort det. Det jeg hittil har klart å finne ut er at det finnes tunere som påstår de kan tune ved å sende de ECU, men har heller ikke sett at noen har bekreftet å ha gjort det. Men det er gladmelding hvis det nå viser seg at krypteringen er knekt. Etter mye undersøkelser I sommer valgte jeg BMW M-Performance power kit. De bytter ECU og du får oppgraderte bremser (Nye kaliptere/klosser og større skiver), større intercooler og ca 10-15% mer HK og Nm. De orginale delene som ECU etc ble lagt I bilen. Pris I Norge ca 25.000,- og ca 19.000,- I Tyskland.
Nei, det er ikke mulig å tune F10/11 ved omprogrammering enda.
Hei, nei du trenger ikke remapped for å montere effektanlegg eller annet innsug. Powerfilter gir deg ikke mer Hk, heller mindre + masse dritt inn I motor. På en bensinmotor uten turbo er det ikke mer enn ca maks 15 Hk å hente på remap, men du kan få en bedre gassrespons som gjør at bilen virker en del sprekere enn økning av Hk skulle tilsi.
Hei mange takk Anathema. uansett hvil det sikkert hjelpe meg å se hva som kan være feil.
Hei Anathema, sendte deg en PM, da er det nok en feil med innstallasjonen. Får ta det rolig forfra igjen. Fint om du kunne sende meg instruksjonen du har. jeg har en I pdf format. Hvilke filer har du kopier og lagt hvor?
Hei, og mange takk for tips Sapio. Har nå avinnstallert hele programmet og innstallert på nytt. Men samme resultat Koblet til kabel, ventet litt og symbolet local tilkobling med gul trekant dukket opp og sa "ingen eller begrenset tilkobling". Satt på tenninga (startet ikke motor) og ventet en stund, men fremdeles gul trekant på tilkoblingsikonet. Startet E-Sys og satt riktig "søkesti" for EST og ODX under settings. Men under connection fliken star det kun 50000 ut for Base port. Startet connect knappen og bilens VIN kommer opp I "Connetction via VIN", velger Connection via VIN som viser: WBAFV31040DWxxxxx_DIAGADR10, (5 siste tall erstattet med "x")men det fylles ingenting ut I Target og Connectknappen er grå, altså ikke aktiv. Jeg kommer dermed ikke videre. Skulle jo tro programmet har kontakt med bilen så lenge riktig VINnummer kommer opp. Har du eller andre tips til hva som er feil??
Høres drøyt ut, men olejeskiftintervall er også avhengig av tid og km. Har bilen gått langkjøring er oljeskiftintervall opp mot 30K, men med småkjøring og mye kaldstart bør ikke intervallet overstige mer enn ca15K. Men det er mange meninger om dette. Så du bør få noe info om hvordan bilen er brukt, før du konkluderer. Ville uansett fått sjekket turbo, eventuelt en tilstandsrapport. Hvor mange Km har bilen gått? Er det E-60 med 2,5(177Hk) eller 3.0(197Hk)?
Jeg mener denne er bygd sammen med radiator, og at du må skifte hele radiatoren med ekspansjonstank.
Hei, mange takk for tips. Jeg har en fil som heter "Code AwayDK.est", mener dette er tokenfila. Da skal jeg prøve uten at motoren er igang, da er det vel best at jeg kobler til en lader. Men går ikke tenninga av av seg sjøl etter kort tid?
Hei, har idag innstallert programvaren på en eldre Windows XP laptop jeg hadde liggende, men samme resultat. Får opp bilens VIN nummer I programmet som sist, men får ikke opp valg av modell I "target". Har deaktivert virusprogrammer og brannmur. Har kjøpt dette settet: http://www.ebay.com/itm/151362340848 Noen som har fått E-sys opp å gå og har forslag til hva jeg gjør feil, eller tips til feilsøking.
