Bmw TIS nedlasting
Hei.
 Er det noen som ve hvor jeg kan få tak i TIS? Må inkludere e61 LCI.
Den onlineversjonen er elendig så den hjelper ikke.
Har rheingold WDS innebygget også?
Mener jeg har sett tegninger av det.. :)
Har lastet ned Rheingold og trålt litt gjennom det. Har funnet ut at om du leter etter Type: SSP så er det utelukkende WDS, du må bruke filter og kun velge at du får opp SSP så må du søke med tekst, tror ikke det finnes noen wildcard dessverre. Litt kødd med zooming men jeg tror du bør finne det meste men det er litt knotete å finne frem synes jeg som Otis sier.
Fra ISTA:
SBT Enclosure WDS-DVD: Search in SSPs
WDS-DVD: Instructions for searching in SSPs
A detailed description of individual buttons can be found in the system overview on the circuit diagram DVD. In this Enclosure, the following additional instructions are provided:
Navigating with hotspots on the SSPs
Text searches in SSPs
The SSPs contain green hotspots. Clicking one of these hotspots opens the navigation tree at the point containing the following additional items of information:
Connector view details
Pin assignments
Installation location
Back to the SSP with the button ”<<” on the symbol bar, centre, top.
Note: For technical reasons associated with the system, the screen masks displayed here are not translated.
For better understanding this description is supplemented with corresponding display views. For technical reasons associated with the system, these screen masks can not be translated into the respective language.
The texts in the screen masks are explained in the accompanying test (and are therefore translated).
The search for components is also possible within a displayed SSP.
  1. Move the mouse pointer over the circuit graphic.
  2. Press the right mouse button.
    The context menu opens.
  3. Click on 'Search'.
    The 'Search' dialogue box opens.
Text search - as usual:
  1. Key in the term being searched for, e.g. the designation of a component.
  2. Click the ”Continue the search” button. If found, the term being searched for is highlighted on the SSP.
Endret av KRapp
