Report: BMW readying MINI-based 0-Series
10/08/2009, 6:15 PMBy Drew Johnson
The MINI brand is vitally important to BMW’s business plan to pass more stringent upcoming emissions and fuel economy regulations, but a new report indicates the German automaker will take things into its own hands.
According to Car Magazine, BMW is planning a new 0-Series model range, set to be based on the third-generation MINI platform. The new model is intended to bridge the gap between the MINI and the BMW 1-Series, and will also go a long way in helping BMW pass more stringent regulations.
Because of its MINI roots, the 0-Series is set to adopt a front-wheel drive setup – a first for the BMW brand. However, like the current MINI range, the 0-Series will have a serious emphasis on road-handling ability.
Power for the 0-Series will likely come from a range of new 3 and 4-cylinder powerplants. Efficiency will take priority over all-out power, although forced induction should ensure lively performance.
According to Car, the 0-Series will be available in three and five-door hatch configurations, as well as a two-door roadster. Despite its MINI roots, the 0-Series’ interior will be thoroughly BMW, complete with all the brand’s technologies.
No launch date was given, but the 0-Series will be available in Europe and the United States.
Kilde: http://www.leftlanenews.com/report-bmw- ... eries.html
Meninger ?
Den dagen BMW kommer med forhjulstrekk er den dagen sola slukker...
Sett heller et ISETTA-merke på den :D
Forhjulsdrift, og 3-sylindra turbomotorer? Ja, akkurat det jeg venter på! :roll:
Jeg vet ikke med en 0-serie (tvilsomt så lenge BMW har Mini), men tresylindrede bensinmotorer med turbo er bekreftet i forbindelse med den nye 1 og 3-serien.
Er "redd" vi kommer til å få også rene bybiler fra bmw..Av åpenbare grunner til dette tenker jeg med en gang på markedsføring i nye marked/kundegrupper, markedsandeler og avgiftssatser/krav.
Slike biler er kanskje ikke sammenlignet med "kjøreglede" eller "tysk kvalitet", som BMW tradisjonelt har villet identifisere seg som, men også disse er jo nødt til å tenke business...Og det var nok det de i stor grad gjorde med en 1-serie, som til dels kan tenkes som en litt større bybil med kjøreegenskaper.
Ellers har jo BMW allerede mini som kan dekke ett slikt marked, så det gjenstår jo å se om de vil "sverte" imaget sitt ved å sette BMW-logoen på en bybil med forhjulstrekk og tre sylindre - så kan andre diskutere hvor objektivt der er å kalle det "sverting". Jeg er ikke i tvil, subjektivt sett :)
Jeg tror at BMW istedenfor velger å gjøre 1-serien (og 3-serien) mer økonomisk... bl.a ved å tilby små 3 sylindrede bensinmotorer (bl.a 1,3 liter med turbo) med varierende effekt. Det er snakk om 140 til 170 HK og det kan jo bli interessant... spesielt i 1-serien. Bensinmotorer med 3-sylindre har forøvrig et morsomt lydbilde på høyere turtall og jeg tror at BMW gjør det rette ved å velge dette alternativet fremfor å utvanne BMW´s tradisjonelle konsept. En lettere 1-serie (og 3-serie) kombinert med lette og mer effektive motorer er utvilsomt veien å gå fremover.
Ja, det tror jeg du fort kan få rett i Fredrik, og på samme årsaker som nevnt ovenfor...økt mulighet for å dekke ett bredere kundefelt, henge med i avgiftsbegrensingene med lettere og mer effektive biler/motorer og holde seg konkurransedyktige ovenfor andre bilmodeller - kort sagt: profitt.
Det bryter (som mye av det andre BMW allerede har gjort, f. eks turbo og fler 4-syl, 1 serien osv) med det mange har tradisjonelt forbundet med BMW og de selv også har identifisert seg med - seks-sylindre, "tysk stål" som blir gradvis mer plastikk, kjøreglede, you name it - men som du sier, det er veien å gå fremover.
Vi har vel en spesielt en billeverandør som nekter å vike fra sine konsepter (les: Alfa Romeo), og importørene av disse bilene kan vel ikke sies å gjøre det direkte bra (deverre eller ei?), uten at jeg her går inn på alle de forskjellige årsakene til det, OT...
edit: æsj, dette ble kanskje litt rotete skrevet..men jeg er trøtt og legger meg heller :) Tror essensen kom fram? :)
Hmmm... ja...nei... Alfa Romeo har jo stort sett konvertert fra fabelaktige V6´ere til rekkefirere og fra bakhjulstrekk til forhjulstrekk. Den siste interessante Alfa´en er etter min mening GTV6 2.5.
Måtte bare lese meg selv om igjen en gang til..
Ang alfa romeo: se det, det visste jeg virkelig ikke..trodde de sto nok så standhaftig jeg, men det var vel mest ett inntrykk jeg hadde og slengte inn i farten ;) Likefullt virker det ikke som barebare å drive med A-R nå for dagen!
Når jeg leste de siste innleggene ovenfor ser jeg at vi egentlig bare er veldig enige ang. hva BMW (bør - kanskje du er enig?) gjør(e) rundt temaene "0-serie" og nedskalering av motorvolum/sylindre i 1-og 3-serie.
Understreker at jeg mener det ville være noe rart å "ødelegge" BMW-identiteten med en minibil, når de har, ja akkurat MINI fra før av til å dekke denne biten! Dette mener ja til tross for at mini ikke skal være en ren bybil, men "stor gocart på 4 større gokarthjul"...Men jeg ville likefullt ikke satt hele formua på at ikke BMW smeller til med en bybil likefullt - kanskje fordi gutta i toppen av bygget i Mûnchen vet bedre enn meg hvordan lage profitt, når det kommer til sist :P
Når Aston Martin kommer med denne "skjønnheten" med hele 68hk og en pris på noen skarve hundretusener er det kanskje ikke så ille alikevel?
Dette har jo ryktes om i mange år, men har jo aldri vært bekreftet av BMW selv. Men det er jo garantert ett marked for disse by-bilene..
Haha den var sø... eh, tøff!
Da slukker sola for deg, for den nye x1'n kommer med forhjulstrekk eller 4x4...
