mkj Skrevet April 26, 2016 Skrevet April 26, 2016 Denne oppdateringen omfatter følgende: Key Changes This is a small maintenance release to fix a few issues reported in 4.1.10. In addition to bug fixes and performance improvements, it includes following new/changed features: Integration with SparkPost replaces Mandrill for optional email service as Mandrill is stopping their current service toward the end of April. Questions in Question and Answer forums can now be sorted by most votes. The "All Activity" activity stream now has an RSS feed. The filter bar at the top of the activity stream no longer sticks to the stop of the screen when scrolling. If you receive a browser notification your notification menu will now reload to get the latest notification. More consistent visual feedback when a post submit or edit is processing to reduce duplicates. Sidebar widgets now how rounded corners to match rest of Suite. Recaptcha style is now a per-theme setting. You can now set which theme should be the default for the AdminCP separate to which should be the default for the front-end. Important Note This is the last release that will support PHP 5.4 as it is end of life and no longer supported by PHP. Please also note that PHP 5.5 goes full end of life in July 2016 so you should look into upgrading if your web host is using outdated versions. We will not immediately stop supporting PHP 5.5 in July but it may follow soon after. Additional Information Important Fixes In addition to many smaller bug fixes and performance improvements, the following important fixes are included: Guests were able to create streams. Logging into the AdminCP using Microsoft Sign In wasn't working. Pas were missing from the report center. In some circumstances, "0" would be removed from post content. MySQL 5.7 could throw an error when trying to clear out sessions. A recent Chrome update caused ACP search results to not display. Replying to support requests on an iPad wasn't working in some circumstances. Security Fixes We are engaging in a third-party security audit of IPS Community Suite so you can expect the next few releases to contain a lot of security hardening. Many of these issues are not critical but we do still want to get the updates to you. This release includes fixes for several security issues: Several CSRF vulnerabilities - most importantly on the process for associating OAuth sign-ins (Facebook, Twitter, etc.) with an account, meaning a malicious user could associate their own OAuth sign-in with another user's account. A session-hijacking vulnerability where after a login key is reset (such as after a password) since a new key is not immediately generated, the account was vulnerable to hijacking until they sign in again. A bug which meant the names of forums or other nodes a user did not have permission to access may have been exposed by accessing a particular URL. Several XSS vulnerabilities meaning if a malicious user could convince another user to perform particular steps, limited arbitrary JavaScript could be executed. A vulnerability where if using the "Download Member List" feature and opening the file with certain applications, malicious user data could cause expressions to be evaluated. And several security improvements: Any existing sessions for a member are now cleared if they change their password, meaning users signed in on multiple devices will need to sign in again after a password change. A more secure hash generation algorithm is now used for login keys. Information for 3rd party developers ModCpMemberManagement can now return NULL to not display the tab. CKEditor has been updated to 4.5.8.
Fredrik Skrevet April 26, 2016 Skrevet April 26, 2016 (endret) Jeg opplever at forumet henger mer igjen og skaper dobbeltposter i enkelte tråder... Endret April 26, 2016 av Fredrik
mkj Skrevet April 26, 2016 Forfatter Skrevet April 26, 2016 Hmm.. Denne oppdateringen (gjort for 15 minutter siden cirka) skal hjelpe på akkurat det. Mulig at det systemet må bygge opp ny cache etter oppdateringen, så vi får gi det litt tid. Fredrik reagerte på dette 1
Shattered Skrevet April 26, 2016 Skrevet April 26, 2016 Kult, skal rapportere eventuelle bugs inn her Har ikke merka noe til at det har blitt oppgradert!
Gabz Skrevet April 29, 2016 Skrevet April 29, 2016 En ting som har irritert meg lenge nå.. Når jeg får vasler kommer det jo en firkantboks på skjermen som du kan trykke på og komme deg til hva enn varselet gjaldt. Men varselet ligger fortsatt ulest i den klokka oppe til høyre. Kan det fikses slik at varselet markeres som lest også når man trykker på den boksen som popper opp? Håper dette ga noe mening for andre enn meg. Bækkmann reagerte på dette 1
