  • Svar 175
  • Visninger 50.7k
  • Full backup of Car's configuration files: It's a good practice to take a full back up of Car's original settings before any changes are made to the car. These files could be used as reference in case
  • Den fungerte som den skulle hehe. Var glatt når jeg testet, så jeg spant en del Det jeg ville teste var at funksjonen funka og at "race flagget" dukket opp.   Når det blir tørt ute, så blir det m
  • Hei. Har nå prøvd å kode opp men finner ikke noe av det dere har gjort. fint om dere hadde lagt ut hvor er dere koder dem? er ute etter å kode følgende.   * Slå av Setebelte varsel * Auto start/st
Hei Bowers. koder du for andre? hva skal du ha for ca det du har gjort, +- noen andre ting.
Holder til i Østfold jeg og.
Endret av Conquest
Pratet me dem har som BMWhat i Tyskland. Og fikk følgende svar på coding av F30:
Hello
Thank you very much for your email
Regarding coding for F-models ...
At the beginning we were not sure if the F-model coding could be realized at all with such an app.
Initially we were quite happy to see that everything went well and we made good progress.
But recently we encountered some difficult problems which delayed the implementation.
Unfortunately I cannot tell exactly how long it will take – but currently I am quite confident that latest Q3 this year we will have a working solution.
As you might know – F model coding today can only be done with a new special cable if at all. This cable cannot be connected to iPhones or Android though – only PCs.
While we have been trying to make it work with our current adapter – it turned  out that unfortunately it is not possible – the technical enhancements made by BMW in the new modern F-series are just too huge and complex.
However therefore we have been working on a new adapter with its own new software and communication which will make it possible to code F-models.
The new adapter is being developed in particular to support the newest F-model communication!
I can definitely say is that the F-model coding will be a free new feature in the app - as it is for the E-models already.
To better understand these F-model problems, the E39, E38 models have been worked on - because we believe that this will help to understand the coding of the F-models as well.
Greetings from Munich
Parvis
  • 2 months later...
  • 3 weeks later...
  • 1 month later...
Da har jeg bestilt kabel og begynt å lete etter E-Sys/PSdZData. Ser ut som jeg kan få tak i E-Sys 3.26.1 og PSdZData 3.56.1. Er dette kurant? Ser noen poster på nettet om at det er gjort noen endringer på PSdZData 3.54 eller 3.55 som gjør dem nesten ubrukelige. Gjelder dette 3.56 også?
Jeg hadde egentlig tenkt å få BMW til å oppdatere software i alle modulene på service til uka, og da trenger jeg vel de nyeste PSdZData-filene? Bør jeg droppe softwareoppdatering i bilen og beholde 2011-versjonene?
Endret av ogee1
Hvis du bruker psdzdata versjon høyere enn 3.55.4 (etter 11\2014) så kjører bmw med "light" utgavene av CAFD. Dvs at uten en løsning som heter TokenMaster premium esys tool eller noe sånt (må betales for) så får du ikke kodet bilen selv med såkalt FDL koding.
psdzdata du må ha for å kode bilen må være tilsvarende eller nyere nivå eller bilen.
Er TokenMaster premium dyr?
Ser også at det er noe som heter E-sys launcher eller noe sånt, men får ikke helt tak på hva den gjør. Noen som kjenner til den?
Nei det var ikke noe alvorlige dyre greier, eneste var at for ikke kommersiell bruk så ble du låst til EN  Fserie, altså valgte du F25 så låser den seg der i minumum 7 dager eller no, før du da kunne velge en annen, som da låste seg i 7 nye dager.
Jeg bruker 3.26.1 med psdz 55.4. Funker knall så lenge bilen ikke er produsert etter oppdatert 2014\11
Har du noen anelse om det er noen store forbedringer mellom 2011 og 2015 software på F25?
Det ser ut som dagens 211-hester har bredere dreiemomentkurve enn 2011. Vil dette endre seg ved en softwareoppdatering, eller er motorparameterne låst til original årsmodell?
Det skal ike endres noe effekt eller noe slikt på motor. Jeg hadde ikke oppgradert om jeg ikke hadde merket noe.
Men når sant skal sies da så er det bare å kode via ista da i stedet men da er det lott begrenset hva man kan kode :)
